1 - 6 of 6 Posts
· Lifetime Lawn Guy
I tried a search and wasn't finding any answers... I know the type "A" is some super sticky/thick grease, and the service manuals call for it specifically and say that no other grease will work... What's the equivelent I can buy at the auto parts store? Regular bearing and axle grease work? I know that's not as thick...
The 8125 transmission I have needs cleaned out and re-lubed. It has a zerk on the bottom, but I assume if one uses the zerk to grease the trans you would need a grease gun with the type "A" grease in it...
Thanks in advance! :trink40:
· 5K Poster!!!
I use Lubriplate red in everything. Its cheap..plentiful and does a fantastic job.
I especially like it in trannys because it gets soft and moves around rather than stays put and fails the tranny gears.
· Lifetime Lawn Guy
Ok, that's good to know. After the warning of "anything else will cause failure" I wasn't sure... I don't see HOW any other kind of grease would just cause it to fail though. It's a pretty simple and low speed gear box. I'd think grease is grease... I usually use Lucas #2 red and tacky for all my equipment.
I'm going to guess that it's Bentonite grease: thick, black, and very sticky. Probably it's most important property is that it will not mix with water, which is why it's used in (Peerless) transaxles. Other types of grease will mix with the water as the gears turn and slowly leak out of the seals but Bentonite grease will not do that. I recently opened up a 25 year old Peerless transaxle and the Bentonite was still thick, black, sticky, and stuck to all sides of the gears and shafts. There was no evidence of any mixing with water or wear on the gears and this was from a John Deere 180 tractor that was used to mow and snow blow.
Of course, if condensation isn't a problem in your area then Bentonite may not be required.
· The Sea of Green Machines
Im using "AX" grease in mine. Wonder what the difference is? Oh well I have a couple tubes of "A" too if it causes me any grief.
1 - 6 of 6 Posts
