The following is an updated list of parts I have for sale. My grand daughter helped me compile this list, and there are obvious mistakes. If you have a question about anything, just ask. I am not going to sell all this off 1 piece, or line item, at a time. I simply do not have the time. I will only sell a minimum of 10 line items per sale. Many packages of new parts also have good used parts min therm. You will get the used parts free. I also have complete motors. Motor parts. Refurbished mowers, and many other Lawn Boy items for sale. Thank You Greg
PART NUMBER
DESCRIPTION
QUANTITY
PRICE
NEW PRICE
TOTAL
303712​
SNAP RING​
5​
$2.12​
$1.06​
$5.30​
307578​
LOCK TAB​
4​
$1.00​
$0.50​
$2.00​
311886​
ROLL PIN​
100​
$0.10​
$0.05​
$5.00​
396521​
NEEDLE & SEAT​
2​
$6.00​
$3.00​
$6.00​
602052​
GASKET​
0​
$2.39​
$1.20​
$0.00​
602587​
PLATE​
1​
$2.12​
$1.06​
$1.06​
602588​
REED​
1​
$10.00​
$5.00​
$5.00​
602590​
GASKET​
5​
$3.00​
$1.50​
$7.50​
602612​
STARTER PIN​
4​
$15.00​
$7.50​
$30.00​
602613​
SPRING​
3​
$4.00​
$2.00​
$6.00​
602617​
WASHER​
1​
$3.00​
$1.50​
$1.50​
602618​
SPRING​
5​
$4.00​
$2.00​
$10.00​
602621​
INSULATOR​
4​
$3.00​
$1.50​
$6.00​
602635​
YOKE​
2​
$6.00​
$3.00​
$6.00​
602636​
WEIGHT​
4​
$6.00​
$3.00​
$12.00​
602712​
BOWL​
2​
$8.00​
$4.00​
$8.00​
602816​
PAD​
2​
$0.50​
$0.25​
$0.50​
603101​
SEAL​
5​
$6.00​
$3.00​
$15.00​
603150​
TUBE​
1​
$4.00​
$2.00​
$2.00​
603164​
NUT​
3​
$2.00​
$1.00​
$3.00​
603440​
SCREEN​
1​
$8.00​
$4.00​
$4.00​
603620​
WASHER​
6​
$3.82​
$1.91​
$11.46​
603952​
REED PLATE​
1​
$10.00​
$5.00​
$5.00​
604074​
INSULATOR​
2​
$6.00​
$3.00​
$6.00​
604116​
GASKET​
3​
$2.43​
$1.22​
$3.65​
604260​
SPRING​
13​
$6.20​
$3.10​
$40.30​
604261​
CLAMP​
1​
$2.00​
$1.00​
$1.00​
604264​
COVER​
1​
$16.00​
$8.00​
$8.00​
604266​
LEVER​
2​
$6.00​
$3.00​
$6.00​
604267​
SPRING​
1​
$3.00​
$1.50​
$1.50​
604274​
FILTER​
6​
$5.00​
$2.50​
$15.00​
604276​
COLLAR​
3​
$17.00​
$8.50​
$25.50​
604277​
SHAFT​
1​
$6.00​
$3.00​
$3.00​
604283​
GASKET​
4​
$4.00​
$2.00​
$8.00​
604291​
SPRING​
2​
$8.00​
$4.00​
$8.00​
604336​
L SCREWS​
2​
$6.00​
$3.00​
$6.00​
604351​
PULL​
3​
$4.00​
$2.00​
$6.00​
604413​
WASHER​
2​
$6.00​
$3.00​
$6.00​
604697​
GASKET​
5​
$6.00​
$3.00​
$15.00​
605058​
WASHER​
1​
$3.72​
$1.86​
$1.86​
605802​
SPRING​
1​
$5.00​
$2.50​
$2.50​
606115​
PIN​
2​
$5.00​
$2.50​
$5.00​
606623​
KNOB​
2​
$9.00​
$4.50​
$9.00​
606786​
PLATE​
1​
$20.00​
$10.00​
$10.00​
607145​
PLATE​
1​
$12.00​
$6.00​
$6.00​
607529​
ROD​
5​
$3.00​
$1.50​
$7.50​
607530​
BRACKET​
2​
$5.00​
$2.50​
$5.00​
607538​
TAB​
1​
$4.00​
$2.00​
$2.00​
607562​
GRIP​
2​
$10.00​
$5.00​
$10.00​
607578​
COVER​
2​
$13.00​
$6.50​
$13.00​
607579​
PLATE​
1​
$3.00​
$1.50​
$1.50​
607657​
ROLLER​
3​
$8.00​
$4.00​
$12.00​
607658​
ROLLER​
3​
$8.00​
$4.00​
$12.00​
607672​
LEVER​
1​
$9.00​
$4.50​
$4.50​
607874​
BOLT​
4​
$4.00​
$2.00​
$8.00​
608281​
SCREEN​
4​
$8.00​
$4.00​
$16.00​
608362​
GASKET​
3​
$2.00​
$1.00​
$3.00​
608584​
BRACKET​
1​
$7.00​
$3.50​
$3.50​
608634​
WASHER​
2​
$1.00​
$0.50​
$1.00​
608817​
plate​
1​
$20.00​
$10.00​
$10.00​
608833​
BRACKET​
4​
$10.00​
$5.00​
$20.00​
609419​
GASKET​
3​
$1.00​
$0.50​
$1.50​
609476​
GASKET​
4​
$2.00​
$1.00​
$4.00​
609477​
PULL​
1​
$9.00​
$4.50​
$4.50​
609493​
FILTER​
0​
$4.00​
$2.00​
$0.00​
609786​
PLATE​
1​
$10.00​
$5.00​
$5.00​
610482​
BULB​
0​
$6.00​
$3.00​
$0.00​
610646​
BOLT​
4​
$9.00​
$4.50​
$18.00​
611184​
BOLT​
4​
$5.00​
$2.50​
$10.00​
611192​
LEVER​
2​
$10.00​
$5.00​
$10.00​
611213​
KEEPER​
1​
$5.00​
$2.50​
$2.50​
611303​
PIN​
5​
$2.00​
$1.00​
$5.00​
611396​
SEAL​
8​
$6.00​
$3.00​
$24.00​
611509​
KEEPER​
1​
$6.00​
$3.00​
$3.00​
611510​
BOLT​
1​
$4.00​
$2.00​
$2.00​
612505​
VANE​
3​
$10.00​
$5.00​
$15.00​
612574​
GASKET​
8​
$5.00​
$2.50​
$20.00​
613142​
SPRING​
2​
$9.00​
$4.50​
$9.00​
613143​
BAFFLE​
2​
$5.00​
$2.50​
$5.00​
613330​
SCREW​
10​
$4.00​
$2.00​
$20.00​
613529​
BOLT​
1​
$8.00​
$4.00​
$4.00​
613529​
BOLT​
1​
$9.00​
$4.50​
$4.50​
614426​
WASHER​
1​
$5.00​
$2.50​
$2.50​
652720​
CLIP​
2​
$5.00​
$2.50​
$5.00​
654710​
WASHER​
1​
$6.00​
$3.00​
$3.00​
654720​
SPRING​
2​
$6.00​
$3.00​
$6.00​
654730​
WASHER​
1​
$2.00​
$1.00​
$1.00​
654750​
GEAR​
2​
$9.00​
$4.50​
$9.00​
654760​
WASHER​
2​
$5.00​
$2.50​
$5.00​
666040​
KEY​
2​
$9.00​
$4.50​
$9.00​
666050​
KEY​
2​
$9.00​
$4.50​
$9.00​
677254​
POINTS​
4​
$10.00​
$5.00​
$20.00​
677299​
POINTS​
4​
$15.00​
$7.50​
$30.00​
677525​
PLATE​
3​
$8.00​
$4.00​
$12.00​
677982​
BEARING​
2​
$24.00​
$12.00​
$24.00​
678113​
FLOAT​
3​
$8.00​
$4.00​
$12.00​
678414​
PLUNGER​
4​
$35.00​
$17.50​
$70.00​
678462​
ADJUSTER​
2​
$10.00​
$5.00​
$10.00​
678736​
NEEDLE & SEAT​
4​
$10.00​
$5.00​
$20.00​
679042​
BAFFLE​
1​
$10.00​
$5.00​
$5.00​
679129​
SWITCH​
1​
$13.00​
$6.50​
$6.50​
679277​
BEARING​
6​
$40.00​
$20.00​
$120.00​
679607​
ROD​
2​
$10.00​
$5.00​
$10.00​
679610​
BRACKET​
1​
$10.00​
$5.00​
$5.00​
679620​
SWITCH​
2​
$15.00​
$7.50​
$15.00​
679691​
BRACKET​
1​
$8.00​
$4.00​
$4.00​
681229​
LEVER​
4​
$6.00​
$3.00​
$12.00​
681737​
RINGS​
6​
$8.00​
$4.00​
$24.00​
681830​
BEARING​
2​
$15.00​
$7.50​
$15.00​
681831​
BEARING​
2​
$16.00​
$8.00​
$16.00​
681832​
BEARING​
3​
$15.00​
$7.50​
$22.50​
681904​
BUSHING​
2​
$15.00​
$7.50​
$15.00​
682683​
LEVER​
1​
$10.00​
$5.00​
$5.00​
683129​
SHAFT​
1​
$10.00​
$5.00​
$5.00​
683581​
LEVER​
1​
$14.00​
$7.00​
$7.00​
683777​
KIT​
3​
$10.00​
$5.00​
$15.00​
683911​
BEARING​
3​
$20.00​
$10.00​
$30.00​
921043​
BELT​
1​
$6.00​
$3.00​
$3.00​
929697​
NEEDLE & SEAT​
2​
$8.00​
$4.00​
$8.00​
931231​
COVER​
3​
$6.00​
$3.00​
$9.00​
931233​
GASKET​
2​
$1.00​
$0.50​
$1.00​
934307​
SWITCH​
1​
$10.00​
$5.00​
$5.00​
941609​
COVER​
1​
$6.00​
$3.00​
$3.00​
945744​
PIN​
2​
$7.00​
$3.50​
$7.00​
957403​
BRACKET​
2​
$10.00​
$5.00​
$10.00​
981362​
GASKET​
3​
$8.00​
$4.00​
$12.00​
