I picked up this 5236 over the weekend for $15. I figured it was a good parts investment but it turns out it's a complete mower. The deck is crack-free and the only hole is the one you see just ahead of the block-off plate. Four green wheels, and a blue on/off/primer knob and starter handle and gas cap. Very low compression; I did have it running by starting it with a drill, but that's the only way it will fire. This is my third 19" D motor of the summer along with a 5232 and 5234.
The D405 here appears to be in good condition otherwise. I'd like to get it running good and add it to the fleet rather than break it for parts. Here's what I have to work with:
I have a complete D motor off a 7260 (the deck was roached). It ran good before I pulled it; just a little slop in the bottom crankshaft bearing. This should be one of the first 2-ring pistons in a D-motor, correct? I can get the D# off the block to verify it was the original motor on the 7260. I already have a set of new rings for a 2-ring D-piston on the shelf. Can I swap over the rod and piston to the D405, hone the jug, and install the new rings on the piston from the 7260? Will that give me an all-needle-bearing rod and piston assembly for the D405 where I can use a 32:1 oil mix?
