1 - 2 of 2 Posts
I have the above mower and had it repair. Had a coil replace, adjusted and clean the carb and replace primer bulb and hose. Took it home for the 2nd time and it would run about 1/2 speed and leaking gas out of air filter. They fixed it again. This time when I mow a hill after about 15 minutes it dies. I get it back on level ground, pump the primer a few times and it will run fine.
When I mow on a hill I go one way then turn around and go back the other way, so the fuel runs to both sides.
Any Ideal what cause this? I'm not sure if I want to take it back again.
Rick
Sounds like your float needs adjusted.
1 - 2 of 2 Posts
