I've got an old Simplicity Landlord (ser # 004998). The engine model number is 243431. It's got the belly blade on it and I like to use it to clear slush or ice off the driveway. First question: what do I have here? what year, hp, etc. Second question: at first startup it runs pretty good but as it warms up it starts cutting out. I try to keep it running by choking it but then it just backfires and may or may not continue to run. I think I have seen somewhere that the problem could be the ignition coil but I can't find the post. I have replaced the points and condenser and cleaned the carb. There is some slop in the carb shafts, could that be the problem? If so are carbs available? I got this for nothing so I don't mind spending a few bucks on it. I just need to know where to start.
thanks
thanks
