1 - 7 of 7 Posts
I performed a simple vanguard for vanguard swap in a 1999 landlord. All went well but when I turn the key off the motor doesn't shut down. The dash light get brighter. I checked the ground wires to the coil and they were both attached. What gives?
If you take the wire from the coil and ground it does the engine shut off? The connector to the wiring harness is plugged in? Next take a meter to the ignition switch to ground and see if you have a ground when you turn off the key.
1 - 7 of 7 Posts
