Hello all,
I'm having an issue with my hydraulic control joystick (please forgive my lack of vocabulary when it comes to tractor talk) in that it won't stay in the "float" position (all the way forward). In the past, the joystick would always kind of lock in that position. When using the front snowblower I keep the blower in this float position so the blower maintains contact with the ground through only the weight of the blower, not down pressure from the hydraulics. Now, I have to hold the stick up in the float position...
Any ideas what might be causing this? I talked to a guy at a local Kubota shop and he said there are two black tubes coming off the botom of the control that I need to take off and empty the water out of. When I look at it, I can see two maybe 1/2 or 3/4" diameter steel "nipples", is this what he's talking about? I took one off, and it seemed to have a watery substance in it, but it was black like oil. Does this sound like an accurate fix for my problem? If so, I must have to drain them both? It appeared that one "nipple" was for the lift control and one for the tilt control, so I only drained the one that appeared to be associated with the lift.
Any other ideas as to how to remedy this situation?
Thanks in advance for your help!
