When I first said what I said, I was referring to the bearings you can pick up at any local parts store. I was thinking about common bearings that have a metal shield covering most of the seal area. Then there is a very small area around the area that the shaft will penetrate through, namely the center most of the shield that has a rubber compound. Take a small screw driver, stick it through the rubber area and pop the seal out. Put the bearing(s) in the spindle so the shield is away from the grease zirk and be done with it. Now the hard part comes. After filling the cavity between the bearings, the grease starts building up pressure until finally grease starts ozzing out around the shaft where the rubber part of the shield is. It is at this point where you have filled the cavity that you should really slow down your pumping grease. Take a shot of grease, wait, another shot of grease, wait, etc, letting the preasure even out somewhat. When you just start to see the grease push the rubber seal ever so slightly away from the shaft. Then STOP.
We haven't gotten in to this, but after removing the blade,and hopefully sharpening it, I hope you make some attempt to balance it by removing metal from the heavy end. What you use to balance the blade is up to you and not part of this thread. But is a vital part of the total process.
