I just bought a "used" John Deere L110 with the 17.5hp Kohler engine that has 180 hours. It seemed to run fine for about 5 hours over 3 uses but then stalled in the middle of the last run.
If I Disengage the PTO the engine can still get the tractor around the yard ... maybe a little sluggish but I don't have a lot of experience to compare.
After cooling down the L110 works as expected for about 5 minutes before stalling again unless the PTO is dis-engaged.
I would like to get through the leaf season before doing maintenance but maybe that was a backwards thought process on my part.
The problem I suspect is related to heat or vibration or load?
I am thinking the possible issues are:
1) Voltage Regulator failing with heat-up
- I will look elsewhere first but may buy a replacement and try
2) battery terminal needs cleaning
- easy to test with bypass to solenoid
3) fuel line blockage limiting fuel feed
- I saw a reference to the IV gas tank to isolate part of that path ... Not sure I have the bits to come up with a bespoke solution
I currently don't have a good meter (any recommendations?) so I'll need to do that ASAP.
things like changing the oil and the air filter were on my list for end of season but I could accelerate.
Anyone recognize the symptoms or otherwise have advice?
