1 - 2 of 2 Posts
I recently got a older 4X4 L235
The rear hydraulic lift for the 3 point isn't working.
I have the manuals, but was wonder if any one has a idea what the problem could be. Just don't want to go into this with out a possible idea what is wrong.
Thanks Matt
Machinery enthusiast
teddy, 1st check is to make sure theres enough hydraulic oil in the rear/transmission. I believe the 3ph uses the same fluid.
Next would be to make sure all the linkages are connected.
Lastly make sure you're running enough rpm. On some modles you have to atleast be 1/2 thottle or higher inorder for the hydraulic pump to make enough pressure to work the implements.
Good luck & let us know.
1 - 2 of 2 Posts
