Greetings,
I just brought my Dad's B8200 standard trany home. It has 130 hrs on it.
Everthing worked fine for a couple hrs, then the bucket did not want to respond nor did the back arms... The hydro pump makes a funny noise and the return line jumps... When we shut the tractor down for a few min, then restarted, the hydraulics worked fine for a minute or two - then same thing..
I looked for a leak on the suction side but didn't find one readily...
Anyone have any ideas on this one? The dip stick shows full on the hydro fluid...
Thanks,
Don
Thanks Mike,
Do you know if the hydro pump is internal or can be accessed externaly? This is not a hst...
Thanks,
Don
No, 'fraid I don't Don. I just threw out some ideas of generic problems that may show your symptoms. Hopefully somone in the know will be by shortly to answer your questions......Mike
