1 - 7 of 7 Posts
It was raining so no numbers yet. Kohler Pro 17.5 HP OHV single cyl Vertical shaft. Ran crummy 5 yrs ago outside since. Price is free. I've heard all sorts of bad things about certain Kohlers This is my first Kohler. Is this a bad one? I'm pretty sure this sit down is a Husqavarna product. All info appreciated Thank you :D
I figure it is one of two things, either a Command or a Courage. A courage will have two angled 'boxes' that go from the head diagonally up to either side that contain the rocker arms. It is not was well reputed as the Command. There were problems with the top cover bolts loosening and being impacted by the flywheel, leading to parts escapes. And oil. Later models are better assembled with less problems.
The Command was also called another marketing name, maybe Pro, I don't remember. Reading, it came to me: Magnum. It(Command) will have a rectangular box for the rocker arms. It is the most bulletproof engine they made in recent history. The K-series is also well reputed, I believe them all to be flat head engines. The Command have hydraulic valve lifters that do not need adjustment. They do recommend use of 10W-30 engine oil over all others, FWIW. Keep the oil and filter changed at least every other season, or in the fall before storage and you should get long life. To my knowledge they are not noted for any particular problem area.
tom
I had one of those on a scotts i used to own the engine was quite good. The only annoyance on mine was when it was cold started it had loud noise and i read its normal something to do with the valves or something cant quite remember. Engine always ran good though.
Thank you guys. I have to line up a truck and some ramps. I'm pretty psyched. It looks to be a Husqavarna. It comes with a manual , Come good weather, I'll search for numbers . Investigating is part of the fun :D
Anything bad you heard about Kohler commands was wrong!
Courage is the one that stained their reputation forever.
The only engines that come in above commands are Kawisakis. They are the Holy Grail of lawn mower engines but they still messed up some too.
Commands are not perfect but they are about the best you can get.
1 - 7 of 7 Posts
