I'm rebuilding a Kohler 301 engine on my Gravely mower using a .010" over piston. The rings supplied with the piston use a three part oil scraper - expansion spring and two oil rings. The problem is that on assembly of the oil ring, the fit is exceedingly tight. It's so tight that you can't simply push the piston up and down in the cylinder but have to use a fair amount of force.
The expander spring is in the shape of a square wave. Cutting off one section would make the whole arrangement too loose. Is this very tight fit normal? As is, I would think premature wear would be inevitable.
Thanks,
Walt Puryear
Athens, GA
Thanks,
Walt Puryear
Athens, GA
