I've got this Kohler M18 with a little over 300 hours on it and I recently discovered oil wetness underneath the engine on the flywheel side. From information I've gathered, some have said the oil breather umbrella valve may be the problem causing high crankcase pressure forcing oil out the front crank seal. They suggested changing the umbrella valve to the reed type. My question is: If I do this, would it possibly stop the seepage of the crank seal. I'm hoping it will, because the engine sets in a 1993 fiberglass Power King tractor and the drive shaft connects to the flywheel side of the engine. I see no way to get to the seal and flywheel removal without unbolting the drive shaft and removing the engine from the machine. Even disconnecting the drive shaft, the engine would need to slid forward several inches to remove the cooling shrouds and a pulley fastened to the flywheel. Should I just go ahead a pull the motor, remove the flywheel and replace both the crank seal and oil breather. Sorry for being so long winded. Any suggestions greatly appreciated.
