Finished my rebuild and got it back on the tractor and did mt first start today.... There is oil coming out of the crankcase breather. I double checked and the breather is reassembled correctly. Is this normal after a rebuild or is there something wrong? Thanks for the help....
Could be the valve guides are worn. With new rings you have more compression and also more pressure in the crank case forcing it up past the valves.
