If you can 'mate' the broken pieces together closely(snugly), such that there is no gap, then do that. Magnetism will have a small field that 'leaks' if you were to sprinkle iron filings on a piece of paper over the joint, but the majority of the magnetic field will flow through. Along that line, if there are small 'chunks' that keep the two pieces separated, I'd remove the chunks if that would get a better meeting of the pieces.
If you add a gap, you are changing the timing of the pulses, adding two smaller ones in place of one larger one. The 'leakage' pulse will be minimal in comparison, IMO.
I have glued together a broken ferrite rod AM radio antenna successfully, and that is the same type of material in flywheel magnets. It likely does not perform as well as a new, undamaged rod, but still gets the stations.
tom
