Is/was the bolt holding the rocker down still nice and tight? If so, and the pushrod is still nice and straight, then next I would check out the lifter (maybe it's collapsed), or the spring for the valve has weakened/failed.
You might consider putting a bit of medium loctite on the bolt as well, to help with keeping the bolt in.dave_r, Both bolts were loose, the bottom one was just not loose enough for the rocker to come off.
Dave Wells, I hadn't thought of that but someone may have thought they were adjustable.
I found the torque spec (100 in lb). I think I'll torque them down and see what happens. Thanks
Cannon
