Give it a little shot of starting fluid into carb next time.If it fires right up the choke is not fully closing or the butterfly is not closed off enough.
I have seen many single courages that needed the purple coated screw turned in a few turns to push choke closed tighter.
If not then I would suspect fuel pump losing prime BUT in less than a week the carb should still be full of fuel and start normally and the fast speed and vacuum pulses would put fuel to carb quickly. I have seen fuel pump issues that would fire right up and only run for 15 seconds and then carb bowl runs low and hasn't sucked fuel from tank yet.
I have had several with plugged or restricted lines or gas tank outlet nipples.
Take line off at fuel filter and you should be able to suck fuel easily out of line by mouth. Half the time it runs our even though not gravity design.
I have blown grass, sticks, lady bugs, japanese beetles out of lines in last 2 years alone.
Old cracked slightly air leaking lines to fuel pump will cause it to lose prime after sitting.
