1 - 2 of 2 Posts
Can someone answer a question about the Kohler compression release? (I have a K301, if that matters.)
I understand how the cam opens the exhaust valve slightly, but what activates the mechanism - how does it engage when starting, but not engage while running?
It's a little flapper on the side of the cam gear ; The flapper spins out at a preset RPM and does not raise the to it's normal height. That is why when checking compression on that engine it must be turned BACKWORDS; As far as the compression release They are for the most part trouble free, and require no maintenance.. Welcome to the forum.
1 - 2 of 2 Posts
