1 - 11 of 11 Posts
Kish JD 318/420/430
Check your VR, then check your stator, one of them is shorted. Have you ruled out a bad stater/ignition switch and tractor wiring? Have you check battery? Could be a bad battery drawing to much current
Battery was about dead jumped it off. Now it is blowing fuse when i pull switch for pto.clutch is unhooked still blows when i engage switch. This is a kohler command engine
Kish JD 318/420/430
What tractor? Could help with diagnosis or problem. Could also still be bad battery (internal short) drawing a high current.
Have you taken connector of at the pto switch or at the clutch? As mentioned short could be in wires between switch and clutch. Maybe the switch is shorting.
1 - 11 of 11 Posts
