Hello, Don't know if this is the right place to ask but my Sunstar Engine has been spewing oil for a while now and I cannot seem to fix it. Was coming out of the breather and down the front as well as out the crank seal. Got a new top gasket and now that stopped.
Last fall I replaced the 2 head gaskets.
Reading the Kohler engine manual and it says the crankcase should have a vacuum when operating. It actually has positive pressure and blows out the oil dip stick tube (when stick is removed).
Checked the cylinder compression and both read 100 PSI while cranking.
I ordered a cylinder leak down tester to help and it will be here in a couple days.
Checked the breather reed and it is okay. I blew some air down the breather ports while it was open and no restrictions seemed there.
The engine runs great and has no power problem operating the 60" mower deck.
She drips constantly and runs thru 1/2 quart of oil in an hour and a large puddle under as it drips off the front in the garage.
Well that's about all I know, so any ideas?
Thanks in advance.
Thanks in advance.
