So I have this Kohler Command 14hp on my lil Simp Regent is running very rich. It starts up fine, but has an occasional miss (probably due to a plug that reads "way too rich") and smells of gasoline around the carb.
I thought being one of these "EPA carbs" they were to run lean and such, but I wonder if there is an internal leak of sorts or if the choke is staying closed for too long.
I'm thinking of just rebuilding the carb (it's cheap enough to get a kit), but if it's something silly like the choke needing adjusted then I may as well look into 'free' fixes, right?
Thanks,
Matt
Thanks,
Matt
