Me thinks you need a new Ignition coil.
That was about the only thing I could think of, too. I don't know much about magnetos. The Kohler engine diagram lists an "ignition module", which looks like the stationary part that rides up against the flywheel and has the plug wire coming out of (which I have been referring to as the magneto). Would this be the part?Me thinks you need a new Ignition coil.
That was about the only thing I could think of, too. I don't know much about magnetos. The Kohler engine diagram lists an "ignition module", which looks like the stationary part that rides up against the flywheel and has the plug wire coming out of (which I have been referring to as the magneto). Would this be the part?[/QUOTE
Yes Sir, that is it easy to remove and replace just remove the two mounting bolts, put the new module on, then put a index card under the metal prongs rotate until the magnets grab the index card. tighten the screws and your done. It is also advisable to put a little Loctite on the screw thread prior to re-install to protect against them coming-out under vibration.
Are you sure you have the right coil and the kill wire is NOT grounded out to frame ground somewhere....Replaced the coil and now I have no spark at all.
The first time I thought maybe I had the gap wrong between the magnet and the coil, because I used an index card. So I tore it all back apart and used two feeler gauges between the magnet and coil. Still no spark. Tried two brand new spark plugs (Champion rc12yc gapped to .040) and a known good one out of my truck.
the electronic magneto needs higher rpm than the points setup to produce a spark. Not likely that hand turning will reach that rpm. I think it's about 500rpm.If you install the coil correctly and gap it with the index card you can chk the spark by grounding the plug to the head or one of the bolts.... you can see a spark in a darken area just by spinning the flywheel by hand (don't get your hand caught in the cooling fins)......
