Hello. I recently bought a Woods 36" Commercial walk-behind mower that has a 12.5 Kohler Command engine on it. The problem is that it isn't very easy to start (recoil start only) and most of the time it wont start at all on CHOKE or full throttle, but if you move the throttle to the slow position (about 1/4 throttle or 1/3rd throttle) it will start in one or two pulls of the rope. Then it needs a few seconds to warm up before moving it to the full throttle position. If you dont wait, it will stall. It will also stall, even when warm, if you move the throttle all the way to the "idle" position.
Its very strange. I've never had an engine that wouldn't start on choke. I've had some that would ONLY run on choke when the carb got dirty, but never one that was the opposite.
It runs awesome after it starts, has tons of power and doesn't use very much gas at all. I can mow about 3 hours on a gallon of gas, and thats after some of it spews out (fuel cap leaks, hit a bump, go around a corner, etc, and fuel sloshes out. Got to find a new cap for it, but its a WOODS tank, not a Kohler tank so parts aren't as easy to find)
Anyone have any idea what might be wrong with this thing? I replaced the spark plug with no change.
I will say that this thing sat for probably 2 years without being started and all I did was drain the old gas and put in fresh. However if the carburetor was dirty, I would think it would run lean, and only start and run on choke, not the other way around. Also, if the carb was making it run rich, and causing it to run TOO rich with the choke on, I wouldn't think it would sip fuel the way it does. Thats why I am stumped. I very very rarely have to have help in fixing anything engine related, be it on a car, or a small engine, but this, as well as my little Honda GX390 that wont maintain engine speed under load, are the only problems I really haven't been able to fix without getting some other opinions.
