Hi everyone. I have Kohler CH23 in a Cub Cadet 3235 that is not running right at all that I have been posting the restoration of it in a different thread. http://www.mytractorforum.com/showthread.php?t=255687
I don't have any experience with small engines but have rebuild several Chevy & Ford V8's as well as antique farm tractors engines. I got most tools or can get them on loan from O'Reilly's.
History: When I bought it a couple years ago it came from a Titan dealer on an online auction that told me it "Ran fine but had some cosmetic issues". I bought it and had it shipped to me in NE from ND. When I got the tractor it would barely run good enough to drive it on the trailer. The gas was like turpentine - so I assumed that and a good carb cleaning would fix it. I have put a bunch of time into painting last fall while the weather was still nice, thinking I would get to the engine this winter. That didn't really happen - so I am working on it now.
Here is a video of it running last week: http://s596.photobucket.com/user/du...D6-8565-0000119B937C5C5D_zpse8c53913.mp4.html
I put a spark plug tester between the plug and coil wire and I have spark on both sides. Compression test: Right: 80-70, left 60. I assume compression should be 120 or higher. I have tore apart the carb and cleaned it really good and installed a carb kit. When I had the left valve cover off everything was nice and clean. I replaced the rear main seal as it was leaking really bad when I got it. The hour meter has under 500 hours on it.
How do it figure out what is really wrong with it? Do I tear the heads off to see if the head gaskets are blown and to see the cylinders? Any advise is really appreciated as I need to decide whether to fix or part out. I don't need the tractor as I was probably going to sell it when I completed it anyway. The price was right and I'm good at painting and fixing cosmetic issues - when I was told by a Titan dealer in ND that it ran fine - I believed them. (won't make that mistake again)
