1 - 11 of 11 Posts
Only difference I found was the main needle
Are they interchangeable?
The reason I'm asking is that I have a K301 without a carb and the only spare I have is one a K241.
go for it, it will work just fine.
Yes they're interchangeable. I once used 10hp carb parts on a K301. They fit and it ran fine.
Inveterate Putterer
I think the 10 and 12 HP motors used identical carbs.
Agreed--it's the same engine block if I remember correctly, with the 12HP K301 just having a piston that's about 1/4 inch bigger or so, for the extra 2HP. I also believe (thought) the carbs were identical. :dunno:
1 - 11 of 11 Posts
