Hi guys and gals. I've got a 07 husquavarna YTH20k46 with the Kohler Courage single cylinder 20 hp. It seems that the solenoid on the float bowl hasn't been working and it makes it almost impossible to start. So i have 2 questions because this is something I've never had to deal with before on previous tractors.
1, the few tractor parts places around here all say that the whole carb has to be replaced because they don't list that solenoid as a separate part. It looks exactly like this one but i don't want to order the wrong part. once i received the bad news from the parts guys i came home and cleaned it up, and got it to start moving and working again. I just don't know how long that will hold up.. So my question, are these usually somewhat interchangeable or will i have to purchase a new carb with this stupid solenoid attached or will the one in the link below work.
http://www.kohler-engine-parts.opee...enoids/carburetor-repair-solenoid-kit-1275733
Question 2, This solenoid is only for anti backfiring correct? in the kohler shop manual and other sources say it's optional. Can it be removed and replaced with a regular bowl bolt or the end snipped off and use as a regular float bowl bolt? I let it idle for a minute or so after mowing and havent had any more issues with backfiring so it's just that starting problem.
I've check the voltage on the power wire and there's a full 12 volts with the key on run.
the ground wire is good.
bench tested it after i free'd it up and it seems to be working now but who knows how long.
Also I've heard that these kohler courage 20hp's are junk but is seems like alot of websites are just full of the bad reviews. Are there any good reviews out there. Mine's got 112 hours on it and i use it for my start-up lawn service (5 lawns each weekend) so i want a mower that's going to go the distance and the mower is awesome, just not sure about the motor...
thank you for your help!
Pete
:thanku:
Pete
:thanku:
