1 - 3 of 3 Posts
If someone already purchased this machine - Kioti DK50 Loader tractor - please share your thoughts?
- is it worth money it cost?
- for how long you have this machine?
- have you ever thought about a trade-in? if yes - why and what machine you would trade in - more HP, less HP - different brand or?
- your experience with having a tractor in Arizona?
Thank you and couple words for this machine, for those, who just thinking about purchasing DK50HP tractor loader:
SPECIFICATIONS: OPERATING WEIGHT (as equipped) 6,208 lbs; POWERTRAIN: Kioti Model 3F1863T 50 Horsepower TURBO DIESEL Engine; Total displacement 111.4 cu inch’s; Rated Revolution 2,600 RPM; TRAVEL SPEEDS: 0 – 17.9 mph; Battery 680 CCA Alternator 2-55A; 11.9 Gal Fuel Tank; HYDRAULICS: 4-way loader control valve; 3-point lift capacity at 24” 2,716 lb; Hydraulic Pump capacity 14.5 GPM; Hydrostatic Power Steering; LOADER: Lift Capacity 2,710 lbs.; Maximum Lift Height 109 in. (2,768 mm); Maximum Dump Angle 58°; Reach w/ Attachment on Ground 70.9 in. (1,800 mm); Maximum Rollback Angle 38.9°; Digging Depth Below Grade 9.1 in. (231 mm); Breakout Force at Pivot Pin 3,900 lbs. (1,769 kg); 72 in; DIMENSIONS: Length w/ 3-point hitch 124.3 in. (3,157 mm); Width 62.8 in. (1,596 mm); Height from Top of ROPS 92 in. (2,338 mm); Wheelbase 71.3 in. (1,810 mm); Ground Clearance 15.2 in. (387 mm); Turning Radius 8.6 ft. (2.6 m);
1 - 3 of 3 Posts
