1 - 7 of 7 Posts
I have both of them suddenly becoming read only. I can't format them with a partition disk utility and diskpart ... I tried every tool that came from my searches on google and none of them works. Have my 2 discs become unusable or is there another solution?
Is that little tiny plastic slide thing on the side in the right place?
There is no tiny plastic on both of them. The microSD card is in an USB adapter and there's no sliding plastic kind of lock. The USB stick is a Data Traveler G4 32GB and no sliding plastic.
If you have one available try them in a different computer.
Both of them with Admin rights.
For the Micro SD I don't know what happen, I was in the process of copying files on it (I want to install Raspbian on my Pi3) and the copying stopped; after that, in the properties of the drive it says read only. It already has an older version of the OS and I wanted to upgrade. Before that, all worked properly. I have one on the way in the mail but if the system brick them all the time it's no fun...
The USB stick, the wife put it in her DVD player and it became read only since then...
1 - 7 of 7 Posts
