Hi Folks,
A guy I work with has an interesting situation. His son was going to mow the lawn and somehow put kerosene in the gas tank. It's a new Craftsman walk behind mower.
I'm a little out of my depth on this one. I said he should drain the gas, change the oil and replace the plug and go from there. Probably disassembling the carb wouldn't be a bad idea, but not sure of his mechanical talents and as it's "new" there may not be a lot to diassemble anyway. Further suggested removing the plug and doing a lot of cranking to try to get as much out as possible. Suggested changin oil as I recall that kerosene is very "gritty" and if it died and the kid kept cranking on it it may have worked it's way down to the crankcase so that wouldn't be good.
Any ideas?
Be well,
Ev
Any ideas?
Be well,
Ev
