41 - 52 of 52 Posts
Discussion Starter #41
I mowed today and it didn't miss a beat. Climbs right up my hills like nothing. THis was the best $800 I could of spent IMO.
If you have any mechanical experience what-so-ever you can do this.
JD X585 owner
Congrats on a job well done! :fing32: :greendr:
I break things
Hey glad it worked out for you. Looks good and i bet it feels like a completely different machine.
Did you get the 26" tires you mentioned in the first post. The max tire diameter for the K66 is something around 23 inches. After going through the swap would hate to see you damage the transaxle. It might not really be too much of an issue just a thought though.
Discussion Starter #44
23x10.50-12 was tire size I used on 10.5" wide wheels.
Not really concerned with anything as I was told it would not work in the first place. Thanks!
Discussion Starter #45
Changing fluid this weekend...
1) To see how hard it is to do with my new configuration
2) Ensure it has 5W-50 in it
3) Can't stop tinkering
LOL
Hey man, I'm doing something similar on my Husqvarna. Can I ask how you tied the tie rods into the pedal assembly? Just drill a hole in it and bolt the tie rod end in or what? Also, how's it holding up?
Holy thread necromancy Batman :)
Hey 1musicnut, got any plans for that k46? If you aren’t too far away, I might take it off your hands.
No plans. The tractor has about 300 hours on it and I got it at 250. Not long after, I noticed it not pulling well up hills - the usual problem. I pulled it out and popped it open but someone had already been into it. I changed the oil and cleaned it up inside, but it had already been done once. I'm sure it needs a rebuild. I didn't go that route because I've got too much incline on my property and want to run a 44 inch snowblower with it so I'd just ruin another one. I'm in Denver. Where are you?
41 - 52 of 52 Posts
