1 - 2 of 2 Posts
im taking apart my engine and got stuck. Kohler k241 (10hp case motor)
how do I take out the connecting rod! I took the 2 nuts off and tryed lifting the cap (with the dipper rod) off but it aint budging. the engine didnt blow up or anything prior to disassembly.
if someone can tell me if their is anything im missing
Tap gently on the connecting rod bolts. Put the nuts back on, and run them down so they're flush with the end of the bolts to protect the threads. Then use a plastic hammer or piece of wood and tap gently. The big end should separate with a few taps.
tom
1 - 2 of 2 Posts
