I have a K301 that I am putting on a 60's Commercial 12 and I cannot find information as to which is the inlet and which is the outlet on the mechanical fuel pumps. I have read that the metal and plastic pumps have reversed inlets/outlets, but which is which? I have a guess.....when looking at the pump side of the engine, the metal pump inlet is on the right?
Thanks in advance to the help.
put your finger over the inlet and crank the engine over, you will feel vacuum on the inlet side or you can use trial and error either way you have a 50 50 chance of being right the first time and no damage will come from it if you are wrong the first try.
