Hi Everyone,
Was looking for some help. I have a John Deere JX75 (serial number over 200k). I was having issues with the transaxle clutch. It turns out the circlip/snap ring under the clutch mechanism loosened up and essentially gouged away part of the main transaxle shaft. This caused the clutch to stick.
Somehow, I need to replace or repair the shaft before I can rebuild the transaxle. I was looking to buy a new or used main transaxle shaft, but the part is not even listed on JD Parts Catalog. The complete transmission part number is AM133605.
Do any of you guys have suggestions / ideas for getting a shaft replacement or repair (rather than buying a brand new transmission)? Does anyone happen to know the original part number for the shaft?
Thanks,
Ryan
Thanks,
Ryan
