New to me today a case 446 . It's pretty clean with a onan 16 twin .
The guy tells me he put in hydraulic oil , so that's got to go . Plus I should change out the rear diff oil too . So what does it need in it and how much . I also bought a plow for it from someone else and don't think the lift arm will work . I goes over the front axle but the hydraulic lines are there and I think the muffler will hit it . Also this plow is a
44" and if I extend the plows width will it rub the front wheels when angled . The cutting deck ( 48" ) hits the rear wheels when lifted all the way up . Is there a adjustment or is something wrong . Can I get replacement decals for the dash and the body ? Its already painted up but needs decals . He tells me its a 1973 but would a onan motor have a spin on filter back then , plus it has duel oval mufflers 1 on each side . Is that stock ? The grill doesn't come out but its painted body color , should it be black like the newer ones ?
Sorry if this is way to much to list . I tried to put in pics but they must be to big , they wont load .:duh:
Thanks .Chris .
Thanks .Chris .
