1 - 6 of 6 Posts
Lucky Man
Just bought a Deere 4520. I already had a 4500 and love it, just wanted a little more horse power for my tiller. My question is I notice when I turn the hydraulic steering whines pretty good on the 4520, is this normal? Also, I think I have a 3 point valve issue too. When I have my tiller on it will slowly settle over a couple of hours and even when the tractor is running it drops a little and then it picks it's self up; like every 10 seconds at idle. Is that an easy fix? My 4500 will hold the tiller up when it is not running and never cycles while running.
My boss just traded a 4410 for a 4520 I run it most of the time.But have not spent much time on it yet.Just a little mowing so far 72MM.I do not even know if there is a draft control on this tractor.But when you say it drops a little then comes up that sounds like the draft control causing that?He also has a new King Cutter tiller for his but has not used it yet.
1 - 6 of 6 Posts
