After doing some Spring cleaning I loaded up some scrap to take to the local recycling yard:
I pick up gas grills whenever I see them because the grill bodies are cast aluminum and the frames go for light iron. The valves are brass too so I toss those in a bucket and bring the bucket to trade in when it gets full. When I was cutting up the grill frame I realized that part of the frame would make a great handle for my 4200W Craftsman generator. I got it second hand but when I downloaded the manual I saw that you could order a carry handle and wheels for it to make it easier to move around. The space between the two pieces of square tube from the grill almost perfectly matches the width of the generator:
A couple of bolts and nuts and I'll be good to go. I think I'll keep the wood shelf there for now but may weld/bolt some steel in place eventually. The wheels from the grill could work but I want to find something bigger. If I can find some rear wheels off of a high wheel push mower that might work. I'll post some pictures when it's all done. Oh and the best part? The generator was free! It had a badly gummed up carb and desperately needed an air filter when I got it.
