Johnson loader project
5984 Views 15 Replies 6 Participants Last post by  ed-nh
making progress on the loader- sub-frame centered- side bracing on- pump in place filter pinned up- now I need to dis-assemble and weld everything up- and check for leaks-need to install the half couplings yet too-
1 - 16 of 16 Posts
Looks nice. Did you remake the uprights? Was this from a different tractor that you modified to fit?
Wow that is looking good, those uprights look like they are factory. Do you have a brace going down to the front end?
the loader was supposed to be removed from a 1886 -that could be but the pump then had to be mounted onto the tractor frame- yes remade the uprights per your length- I did post 2 more pics but they did not upload? used 1.5 pipe size sch-40 black and flattened the ends-mounted pump on loader frame as in the Johnson manual- will snap a few pics of my bracing- all quarter inch plate-gusetts where needed
Only the first picture in your original post shows up. Nice work with the loader :fing32:
just figured out how to rotate my pictures-here`s one with how I made the front brackets
That looks like it is coming together, the front bracing looks factory. It will look nice all painted up, are you planning to get Johnson decals for it?
I hope you don't mind BB, but I edited your posts to fix your photos for you. I did nothing else but work on the image code tags.
I don't know what model you have, but we have some manuals for these loaders on the site here:
http://www.mytractorforum.com/forumdisplay.php?f=546
thank-you DJ- I know for some reason- sometimes my pictures don`t post- yes- after I get it all mocked up- I will disassemble- weld up everything and check for leaks- put it back on and check operation- that`s when I can take it all apart again and blast it- paint- new hoses-lines and yes new decal set- I need to weld in my half couplings yet and get all the drill shavings out of those uprights
I like how you made the front brace bolt to both of the front end bolts, very smart design. You should start building new loaders for Bolens because that upright and the front brace look identical to mine.
thanks BK- as tough as it was to find a loader- I wonder if there is a market for a "kit"-just all the steel pcs cut and drilled-I think I could do all the frame parts- no bucket- for around 200.00-matbe when I am done with this project- I will tack one up
Next time you're in PA you can stop and fix my Johnson loader on my JD 140 its well quite a mess LOL Did you make the bucket too?
Maybe you can build one for my 1886 someday.
the gent I got it from just bought the bucket from kwik-way- so that saved me some fab work-I must confess though It`s almost like cheatin`having access to the plasma table-cad- and a shear-I will be sure to make detailed measurements and drawings of parts so I can share the info
That looks great! Excellent job, will be following the progress on here.
That fabrication on the frame looks great. You did a really nice job on that.
1 - 16 of 16 Posts
