I would contact JB Jr. and ask if it will work on your tractor. They will know if there are frame problems. Roger
Thanks. yes. thats what i did first. they said it is compatible. But they don't have any comment on how strong the tractor is. or how well it can handle the bucket. they actually suggested this forum to check if any real user has any comment.I would contact JB Jr. and ask if it will work on your tractor. They will know if there are frame problems. Roger
If John Scheele says it will work. Then don't worry about it. I have known the Man 20 years and Have never none Him to Lie about any of his Products. He actually Looks at the Machines In Person when designing His Buckets. He will be the first to tell You That he doesn't recommend a Machine. For example He doesn't recommend the Current Husqvarna Lawn or Garden tractors. for use with his Bucket Even though it will fit On them. It's because of there new stamped Frame design:thThumbsUThanks. yes. thats what i did first. they said it is compatible. But they don't have any comment on how strong the tractor is. or how well it can handle the bucket. they actually suggested this forum to check if any real user has any comment.
Can a K46 or a K58 handle a bucket like this?If John Scheele says it will work. Then don't worry about it. I have known the Man 20 years and Have never none Him to Lie about any of his Products. He actually Looks at the Machines In Person when designing His Buckets. He will be the first to tell You That he doesn't recommend a Machine. For example He doesn't recommend the Current Husqvarna Lawn or Garden tractors. for use with his Bucket Even though it will fit On them. It's because of there new stamped Frame design:thThumbsU
Yes with In reason. I wouldn't do a Lot of Digging But to Move Loose Material It should be fine. Meaning I would Not Buy the tooth Bar with either Of those Transmissions :thThumbsUCan a K46 or a K58 handle a bucket like this?
Good to know. Thanks!Yes with In reason. I wouldn't do a Lot of Digging But to Move Loose Material It should be fine. Meaning I would Not Buy the tooth Bar with either Of those Transmissions :thThumbsU
How many hydraulic outlets do you have to have so you don't have to change the angle of the plow, or raise and lower it by hand, without getting off the tractor to adjust it? My friend has a Cub 1863 with the 4 hydraulics. He says he has to get a tractor with four hydroponics like the 1863 to fully operate a plow without getting off the tractor at any point.If John Scheele says it will work. Then don't worry about it. I have known the Man 20 years and Have never none Him to Lie about any of his Products. He actually Looks at the Machines In Person when designing His Buckets. He will be the first to tell You That he doesn't recommend a Machine. For example He doesn't recommend the Current Husqvarna Lawn or Garden tractors. for use with his Bucket Even though it will fit On them. It's because of there new stamped Frame design:thThumbsU
Cub 1863 Did Not Have More than 1 set Of Outlets(total of two) Because You raised and Lower the Blade or Blower from the On Board Hydraulic cylinder.How many hydraulic outlets do you have to have so you don't have to change the angle of the plow, or raise and lower it by hand, without getting off the tractor to adjust it? My friend has a Cub 1863 with the 4 hydraulics. He says he has to get a tractor with four hydroponics like the 1863 to fully operate a plow without getting off the tractor at any point.
I guess I misunderstood him from what I just found out from him. He wants a new 700 series then he is covered. He wants to keep his butt in the seat without getting off to change the angle. I thought his 1863 was that way.Cub 1863 Did Not Have More than 1 set Of Outlets(total of two) Because You raised and Lower the Blade or Blower from the On Board Hydraulic cylinder.
None of the Cub Cadet Garden tractors or Super Garden tractors Before the 3000 series had more than 1 set of outlets.
The same cylinder that raised & Lower the deck also raise and Lowered the front Blade and snow Blower.
With the 3000 series You Got Up two two sets of Outlets for a Total of 4 In order to use the front Hitch. But the Front Hitch for the 3000 series could Have Manual angle Instead of Hydraulic angle Then You only Installed 1set Of outlets for a total of 2. But If You wanted Hydraulic angle you installed 2 set of Outlets for a total of 4 But You could Have 4 Hydraulic Valve On the 3000 series To control front Mounted attachments separately(angle & raise & Lower) from Mid Mount deck and with the 4 valve Installed On the right fender You could Operate the 3 Point separate from deck & Front Hitch.
My X748 has 2 sets Of Outlets for a Total of 4 There is a aftermarket Kit out from Aux Hydraulics for The X700 series that will give You a 3rd set Of Outlets, But You still only have two Valves. I Now Have a Dump cylinder shut off On My 45 Loader So I can control the 3point Hitch separately from the Loader. Got that from Aux Hydraulics. Now the Loader won't dump if I want to raise and Lower the 3point Hitch if I close the shut off:thThumbsU
Yes it Has 1 set of Outlets which is needed to control the angle cylinder On a Blade But lift was Taken Care of By the Mid Mount Rocker-shaft that controlled the Mid Mount Mower Lift as well as the 3point Hitch The Blade frame connected to the Mid Mount Mower Lift But the angle cylinder connected to 1 set of Front OutletsI guess I misunderstood him from what I just found out from him. He wants a new 700 series then he is covered. He wants to keep his butt in the seat without getting off to change the angle. I thought his 1863 was that way.
