I picked this up last fall from a guy that lives just on the north side of town, just the tractor and 47" deck. At some point, the KT17 had been upgraded to an Onan P218G, so I consider myself to have "lucked out" in that regard...
I swapped the tires and wheels over from the 210, and shot a coat of paint on the hood to match the newly powder coated sheet metal.
Just before New Year's, I drover over to meet a fellow WFM'er and pick up a couple of new toys from Iowa...
I also picked up a 54 blade locally, and had the tractor outfitted for winter (even though I only used it three times...
I also picked up a newer 46" deck with the powerflow pulley and decided to refurbish it with bearings, gator blades, belts and paint. I want to put a speed-up pulley on it, but figured I'd try it out as-is first.
I plumbed up a pair of rear hydraulic ports (it's the factory rear hydraulic kit), which I plan to use for hydraulic raise/lower upgrade on my aerator, as well as other rear implements.
My dad wanted to step up from the 208 (which he kept also), and found this 420 with weights and MCS for a pretty good deal. It needs a few things like seat suspension bushings, a good cleanup, and maybe tires.
Last week, I finally decided that I needed new shoes for the rear of the 317, as the Duro's just didn't give me an aggressive look like I wanted. I will mount them on a pair of 455 wheels.
I always have a few (dozen) on-going projects, but here is a sneak peak at one that I'm pretty excited about (second to the power steering upgrade...)
