Do you know how to use a VOM meter or 12 volt test light? If so first verify the pto switch is working by checking the 12 volts into the switch and when set to the on position that 12 volts is coming out. Test light will light, meter will show 12 volts. If that is working then verify 12 volts at the pto. if the coil is open you still see 12 volts there, if open wire between switch and coil there is no 12 volts. The pto is grounded somewhere either via a wire or grounded with a bolt. With the pto in your hand set the VOM meter to ohms. short the leads and zero out your meter, then put one lead on the hot side and one on ground of the coil. You should get a reading other than zero. If not on the right scale move up to the next setting on the meter. If you were at 1k ohms set to 10k ohms. You should get a reading of something for example 34 on the 10k setting is 3,400 ohms. Don't use this number as gospel it's an example only. If you can't get a reading at all and only shows either 0 or nothing, they are two different readings. Then the coil is defective. 0 ohms is a short, infinity or nothing read is an open like when the leads are just hanging in the air. You shold be able to tell if the voltage and coil are good. Now if that all checks out there is an adjustment for the pto gap. Lets see where your at first.
