I have an X380 with the powerflo bagger. The belt that drives the bagger seems have a relatively low tension. I recently replaced the belt with a JD belt that is supposed to be the correct size and it appears to be very close to the original belt. However the belt has so much play and movement when engaged that it has rubbed some of the plastic fittings and covers that are in close proximity to the belt.
With the new belt, the bagger works but I am just a bit concerned that it is not tensioned properly. Any thoughts or suggestions? I have verified that the belt is installed coorectly.
