Just purchased my first “large” tractor for our 20acre hobby farm, a John Deere 1020 with a front end loader. The carburetor needs some help. The float needs replaced (fills with gas) and the electric shut off-load adjustment valve leaks. I would like to do away with the electric shutoff and just install a regular adjustment needle and I also would like to order a full rebuild kit (bowl gasket, float, needle, throttle shaft bushings etc) however I can’t find a model number anywhere on this carb. Any help is greatly appreciated!
Thanks everyone for the help ! I ended up making my own gaskets and I repaired my float. Found a previous forum where someone baked their float at 275 degrees n watched for a dark spot to find my pinhole.
