I am looking at this John Deere LT 155 and the transmission will not turn the wheels on the ground when engine running. When you jack it up and get all pressure off the shaft turns a little...but when you grab it with your hand it will stop without much pressure. Does this sound like major problems inside? The splined shaft with the pulley on top the tranny is all good and is not stripped by the way..everything there spinning like it should. The plastic fan is like new so no worries there.
I was trying to find the name of this tranny on some nameplate stamped or riveted somewhere but I can not find one. I think it might had been some sort of decal or sticker towards the back of the mower..which I guess would be front of tranny or back?? But it fell off because I can see the adhesive mark where it was. Any other stampings anywhere else in the tranny housing I might find to tell the exact kind of tranny it is? I am thinking it is a Tuff Torq K51 B but I am not 100% sure. Reason I say this is some guy told me all 155s had this type of tranny?
Also I noticed one of the keys that side in slot in the wheel shaft was missing when I removed the tire. The tire looked to be recently replaced as it still smelled new. Would not having this key cause the tranny maybe to overheat and burn up because one side was maybe spinning and one side was not? The side which was missing the key was on right hand side...I will call it the passenger side like on a car.
