My 2007 John Deere La 110
Single Cylinder with Engine Model . . . . . Briggs & Stratton 31 /19.5 hp.
It appears to be leaking oil up around the front of the mower where the valve Cover say OHV.
It's leaking on the right side (so if you were sitting on it...that right) Down by the park plug area and I know these engines have an issue with the Valves needing to be adjusted something like every 200 hrs otherwise the starter won't start due to to much pressure.
But I am at a loss as to why it's leaking oil.
It seems to run fine. But I can smell a bit of oil as I cut from time to time and that's prob because it's getting on the hot exhaust area.
Does anyone know if this is a common/ easily fixable problem with these.
I included a picture of the engine i have (not mine but off of brads new and used engines )
This is my engine : http://www.brandnewengines.com/31p677-0144.aspx
Does anyone know what's causing it & if it's a major fix?
I'm not losing a lot of oil. But enough that every couple times i cut... I want to check it to make sure it doesn't drop to the add mark or lower. Slow leak.
