Well, now it's my turn... My John Deere GX345 won't fire.
The tractor will turn over just fine but all of a sudden the tractor won't run. Here's what I've done:
- I replaced both spark plugs.
- I verified spark on both plugs by touching them to the block while cranking and there is spark from each plug.
- The seat safety switch is working but I jumpered it anyway (and I am getting spark as well).
- I don't smell raw gas while cranking the motor.
- I can pour some gas down into the carburetor intake and the motor will fire and run fine for a few seconds, but never stays running (again, I have spark).
- The oil level is just above the full mark on the dipstick (I make note of this because I know some motors have a low-oil cutoff but I'm not sure if there are high level cutoff's, but again, I'm getting spark at the plugs)
- When I remove the fuel line to the carburetor and crank the motor, fuel squirts out.
- When I turn the key to the ON position there is a red and green light illuminated on the control board (not sure what's normal/not normal).
- I removed and cleaned the carburetor. I removed all the jets, cleaned the ports and the float works, etc.
- The bowl had fuel in it when I removed it and as stated above I have fuel flow to the carburetor.
- I don't have old fuel and I've been using the machine daily with no issue until now.
- I bought a time delay module but I don't think this is the problem. If it was this switch I would have no spark (correct?).
- That's where I'm at at this point.
I'm not sure about the emergency fuel shutoff solenoid on the bottom of the carburetor bowl. I assume that when the motor is started that the pin is supposed to retract to allow flow, correct? I don't know how to tell if this is working. How do I test it? There is only 1 wire going to the solenoid. Are the mounting threads the ground and the wire is the positive? Can I just cut off the end of the pin/shaft to see if it will run as a crude test to determine if it's the solenoid that has failed? Should I remove it from the bowl, ground it best I can and turn the key? Should that pin retract when I try to start the machine?
I'm not sure what to try next. I'm scratching my head that I have spark, fuel to the carb, but it won't run.
I hope someone here can help.
Thanks :thanku:
Thanks :thanku:
