It's an automotive Challenger 2 post lift. I built the adapters to hook onto the lift pads. They fork the tire like a wrecker with a wheel lift. I have the mower kinda catty corner, or diagonal so I can get a lift pad under the rear weight which is flat. The majority of the weight on this tractor is on the front wheels, and even though the mower weighs 950 lbs on a 7,000 lb lift it bobs a bit on the longer arms. Ideally I'd drive into the lift and pick it up with the shorter front arms.Question- it's up in the air in your pictures... How's you do that, and if you did, why need rear adapters?
Great progress, BTW!
To answer your question a bit more thoroughly, I had taken the deck off in the beginning and noticed there were no decent lift points on the machine. The whole left side from wheel to wheel is nothing but gas tank and on the right side there's a small bracket. I had put a lift pad on the deck lift arm, one on the bracket and one under the back which is how I got it in the air initially. It wasn't very stable and made me a bit nervous. Browsing turf lift equipment gave me the idea to build the adapters.Question- it's up in the air in your pictures... How's you do that, and if you did, why need rear adapters?
