1 - 2 of 2 Posts
I have an old 1968 JD 110 that has a clutch problem. Since i put on a racing pulley on the engine, i had to change the belts, so as soon as i release the parking brake, the pedal snaps back, and the variator handle has no tension whatsoever. With the variator out, you have to pull back on the pedal with your foot in order to get it to drive at full speed, which the pedal should move all the way back on it's own. If you move your foot, the pedal depresses a little, and the tractor slows down real slow. What can i adjust, or change in order for this problem to stop? I put on a 5 3/4 racing pulley on the engine, and thought maybe the belts stretched, but im removing it anyway to put the original pulleys and belts back on, and the mower back on. I need help!!! Thanks!:fing20::thanku:
1 - 2 of 2 Posts
