1 - 2 of 2 Posts
Is there any way to install a loader on a jd 950 if it doent have anywhere to run the lines to the pump?
And if there is, would it be feasible?
Yes it is possible to install a loader. The kit to add the control valve is no longer available from Deere, but you could get an open center valve and plumb it in. I believe if you get a new loader from a supplier such as Woods or Koyker, they will supply loader valve and fittings. Power steering is another consideration when adding a loader. Manual steering gets tough to steer when lifting heavy loads. There is a company named Jackson Power Steering that makes kits to install power steering.
1 - 2 of 2 Posts
