1 - 7 of 7 Posts
I have a John Deere 455 you have to pull up on the steering wheel to give it to steer if you release the pressure there's no steering at all any suggestion?
stripped splines on steering shaft - either on the wheel, or in steering hydraulic valve.
This is my guess as well. It would be unusual for the steering valve to wear. The steering shaft is normally the culprit. You should be able to find a decent used shaft on EBay or buy a new one from mother Deere.
Kish JD 318/420/430
Rudy this thread was originally in another area, the mods/admis are a little behind in moving threads that are in the wrong areas. There are more but wish there was a way to report/flag it like under the old system
1 - 7 of 7 Posts
